Tråd: Alcatel makes the world's dumbest 4G hotspots -Y800 and Y850
I see these devices marketed in Africa. No signal information whatsoever more than bars showing RSSI. No antenna connectors. At least the Y800 has a sleek design whereas the Y850 is just square. And those are the only hotspots marketed by ISPs in new LTE markets such as Rwanda. 4G customers deserve better.
http://ukblog.im-mobility.com/configuri … s-hotspot.
I just helped a lawyer secure his wifi and set up an admin password instead of "admin" on a  Y800 plus that we enabled AP isolation.
Dumb gadgets get dumb reviews
http://www.gadgetheaven.co.uk/can-use-a … broadband/
The man things missing from the Alcatel routers are the possibility ti set a specific lte-band, 5GHz wifi, 802.11n wifi and showing the most important signal parameters SNR ( SINR) and cell id PCI.
Go for ZTE or Netgear hotspots instead.
