Tråd: Dovado Tiny AC *ny router*
http://www.dovado.com/en/products
http://www.dovado.com/media/rokgallery/a/a1d336af-36df-4947-f59c-1a008cccfecd/0535e70b-9369-4942-b7be-0e3abcd97562.jpg
Produktblad:
http://www.dovado.com/images/PDF/DOVADO … ASHEET.pdf
Youtube presentation:
https://www.youtube.com/watch?v=6Xc5ykpcQIk
FEATURES
  • Connects (as network client) to a neighboring 2.4/5GHz WiFi network
  • Fixed-broadband speed throughput at up to 1Gbps
  • Mobile broadband access in Routed/Bridged mode* (300 Mbps with 4G)
  • Maximal uptime with SmartUSB™ and Connection Tracker™
  • Supports many different USB modems for mobile broadband*
  • Automatic Failover between USB modem/Ethernet WAN/SpotBoost™ interfaces (in any order)
  • WLAN Encryption and MAC address Filtering
  • Port-Forwarding & Remote Management
  • Dynamic DNS Services
  • SMS Mailbox/Remote Control**
  • SMS/E-mail Notifications
  • SMS->SMS & SMS->E-mail Forwarding
  • Live Firmware Upgrade (with SMS/E-Mail Notifications)
  • PPTP-based VPN Client
  • PPPoE (Ethernet WAN port)
INTERFACES
  • USB: 1 x USB 2.0 high speed ports for mobile broadband modem*
  • LAN: 1 x 10/100/1000 Mbps Ethernet port for wired device(s)
  • WAN: 1 x 10/100/1000 Mbps Ethernet port for wired Internet
  • WiFi: AC750 (300Mbps b/g/n on 2.4GHz & 450Mbps n/a/ac on 5GHz), internal 2.4GHz antenna & external dual-band 2dBi detachable antenna
Sv: Dovado Tiny AC *ny router*
Hej allihop,
Tiny AC modellen kommer finnas i butik om cirka 2 veckor.
Sam / Team DOVADO
Vad beräknas slutpriset bli?
1099:- tar Kjell &Co (tomt lager)
http://www.kjell.com/sortiment/dator-kr … ter-p96388
PC för Alla har testat:
http://pcforalla.idg.se/2.1054/1.612544 … ojligheter
1000:- riktpris
How much current does the router (with modem) need over POE and what voltage is used? Do you have any recommendations for a power source and how to inject the power in the LAN cable?
( posted a link to this thread on a German forum where the was a question for a POE powered 4G router)
Hi,
This router does not facilitate Power-over-Ethernet. I'm not sure what gave off the impression that it would.
Thanks
OK
While we're on the subject ;-P Is there any future where any Dovado product would/could be SUPPLIED by PoE?
Hi,
No foreseeable plans for that as our products are designed primarily for indoor use.
Thanks
Sam / Team DOVADO
Newsflash: You CAN use PoE indoors and benefit from fewer cables and whatnot ;P
Sure, but we don't develop products or features for the minority cases. We think broader than that. PoE is an unnecessary additional cost as well as generator of heat we could do well without.
Thanks
Om man byter från den gamla Tiny till den nya,
kan man spara inställningarna då i den gamla och sedan ladda in dem i den nya ?
Hemma: Telia fiber 500/500.
Tyvärr inte.
