Efter ha sökt runt lite på nätet så har jag hittat detta.
Models
HP hs2300 HSDPA Broadband Wireless Module RN005AA#AC3
HP hs2310 HSDPA Broadband Wireless Module RT052AA#ABA
Introduction
The HP hs2300 HSDPA Broadband Wireless Module is an integrated WWAN module for select HP notebooks that provides
connection to Vodafone networks in Australia, France, Italy, Germany, Netherlands, New Zealand, Spain, and UK, and permits
roaming on Vodafone and partner networks in more than 60 countries. (Separately purchased Vodafone service required.) With an
HP Broadband Wireless notebook and Vodafone service, you can check e-mail, browse the Internet, and connect to corporate
networks from anywhere within the coverage area-whether you are stationary or on the go. Begin to enjoy the freedom of connecting
in more places, the speed of broadband, the coverage of 3G networks, and the security, reliability, and ease of use of HP business
notebooks today!
The HP hs2310 HSDPA Broadband Wireless Module is an integrated WWAN module for select HP notebooks that provides
connection to Cingular Wireless networks in the United States and to Cingular's roaming partners in over 100 countries. With an HP
Broadband Wireless notebook and Cingular service, you can check e-mail, browse the Internet, and connect to corporate networks
from anywhere within the coverage area-whether you are stationary or on the go. Begin to enjoy the freedom of connecting in more
notebooks today!
Som sagt så tycks hs2300 vara anpassat för vodafone "telenor i sverige".
På samma vis som hs2310 tycks vara för cingular.
PDF från HP
http://h18000.www1.hp.com/products/quic … 694_na.PDF
Antar då att de har operatörs låst dem vilket är aningen jobbigare.
Under huven på kortet:
Chipset and Module Model Qualcomm MSM6280 chipset; Sierra Wireless MC8775 module
Så tycks de vara ett Sierra Wireless MC8775
Lite info om kortet: http://www.mobilabredband.se/forum/viewtopic.php?id=132
Hittar inte så mycket (ingen) information när det kommer till låstning/upplåsning av det.
Frågan är hur det blir när du stoppar i tele2 sim kortet, programvaran som följer med är som sagt anpassad av och för vodafone så deras inställningar är redan inmatade.
När du har kortet i och startar programet vad säger det?
Kan inte registrera simkort eller får du motaning men kan inte ansluta?
Om du nu lyckas skapa en anslutnign med rätt apn adress "internet.tele2.se" så kommer den hamna under nätverksanslutningar "fjärranslutningar" som då gör att du inte kommer behöva vodafones program mer.
Utan du kan göra en genväg från anslutningen till t.ex. skrivbordet så koppla upp dig där igenom.
