Tråd: Firmware Upgrade HUAWEI E398 11.335.27.00.000 Debrand Vodafone K5005
Hi to all,
I'm from Italy and new in this forum and want to share this new firmware upgrade for the 4G LTE Huawei E398 stick.
This new firmware is NO-CUSTOM firmware, mean that if you want to upgrade your version in your E398 stick and it have any customized version (customized are firmware that ending with a number ...eg. Vodafone K5005 have version 11.335.21.20.11 see latest "11"), the upgrade process ask you for password upgrade (surf on web to calculate your via IMEI).
This version is E398_Update 11.335.27.00.000.B757
http://www.mediafire.com/download.php?4jd52k1uewsi9h8
I've used this upgrade firmware to de-customize the Vodafone K5005 into a perfect HUAWEI E398.
Please if anyone have an original HUAWEI E398 or E392 (NOT CUSTOMIZED) please share the Mobile Partner files inside the stick, via any filehosting (mediafire or other) MANY THANKS
You can also upgrade your Mobile Partner with the v.23 version, but I don't like the new graphic interface, and for this reason I'm searching for the traditional Mobile Partner look version...
