Tråd: konfigurations guide e398 (dovado 4gr)
Vilka inställningar ska man ha på mtu mru ska man ha mss clamping ? ja vilka inställningar för bästa resultat vill ngn vänlig själ som håller svaren dela med sig?
MobilaBredband.se © Störst på Mobilt Bredband sedan 2007 » Huawei » konfigurations guide e398 (dovado 4gr)
Prova 1400
Tips ar att kolla wikipedia om vanliga varden.
Vill du ha korrekta varden behovs bla operator och abg typ da det skiljer lite for att kunna get ett svar.
Kommer gå upp på våran FAQ lagom snart:
1) Insert the USB modem into your computer and connect to the Internet.
2) Download TCP Optimizer: http://www.speedguide.net/files/TCPOptimizer.exe
3) In the program, go to the “MTU/Latency” tab.
4) Click on the "Largest MTU" button.
5) Once the test is done, it'll say at the bottom "You can set your MTU to...."
6) Back into the DOVADO router, go to the SYSTEM->NETWORK SETTINGS page and deselect "Let router use safe settings" and fill in the MTU and MRU field with the value you got from TCP Optimizer.
7) Make sure to Enable MSS Clamping.
8) Save and Restart with USB modem inserted.
Tackar ska se hur det funkar nu:)
Should i use drop ping request sam? on dovado 4gr
If you like.
It will not affect gaming or anything else ? is it for the better
It only blocks incoming ping requests to your router from outside.
unless something needs ping replys, drop it - or someone could mass ping you and get you to lag in game... Ping of death in another sense.
I have done all this and i only use 4 should i use Tx Queue Length to and shall i set mru as the same as the mtu
