GPS antenna with SMA Plug connector compatibility
Alpine: Blackbird PMD-B100 Portable Navigation System.
Falcom: Active GPS antenna FAL-ANT-3, Active GPS antenna FAL-ANT-4.
fTech: GPS Antenna SMA FGPANE1A2, GPS Antenna SMA FGPANE1A5.
GlobalSat: Antenna AT-65-SMA, G5010U, G5040, TT-300.
Holux: GM 82 Engine Board.
Navman: GPS antenna ANT06A, TeliNav Cube 2 w 850 1900 MHz, TeliNav Cube 2 w 900 1800 MHz, Tracker 5100, Tracker 5110, Tracker 5380, Tracker 5430, TRACKER 5500, Tracker 5505, Tracker 5600, Tracker 5605.
Rikaline: A-10302-SA, A-10305-SA,GPS-300 Black Box.
Standard Horizon: CP 150 (Passive 3 foot Only), CP 160 (Passive 3 foot Only), CP 170 (Passive 3 foot Only).
Synergy Systems: AR-10K GPS Antenna SMA, AR-10S GPS SMA Antenna 1001411, AR-10S GPS SMA Antenna 1001414.
Tele Type: Satellite Tracker v2.0.
Trimble: CrossCheck CDPD, CrossCheck GPRS 1900, CrossCheck GSM 900, CrossCheck GSM 900 1800, Lassen? iQ module 2000A, Lassen? SK II board, Lassen? SQ module, TNL 1000 Panelmount GPS (5.2 VDC).
u-blox: LEA-LA GPS Receiver Module, TIM-LA GPS Module, TIM-LC GPS Module, TIM-LF GPS Module, TIM-LH SuperSense GPS Module, TIM-LL GPS Module, TIM-LP GPS Module, TIM-LR GPS Module.
