Tråd: Secure WPA2 connection
Latest firmware here (4.3.0).
Clients: debian stable (lenny), debian unstable (sid), htc-desire android (Froyo 2.2), ubuntu karmic.
Unsecure communication works as expected.
wpa_supplicant (various versions) used in most installations (don't know what the android uses) on the client side.
I have another very similar setup (bsd based, pfsense 1.2.3, hostap): no problems, all clients work as expected.
Dovado router set to:
Wireless Band: 802.11 b+g (or 802.11 b+g+n), doesn't matter.
Authentication Type: WPA2 (AES) or WPA/WPA2 Mix mode (TKIP or AES), channel 9 (default) or channel 1 (reconfigured)
Internet Connection Settings: Ethernet cable in WAN port
and constantly rebooting between configurations, doesn't matter, no joy.
wicd network manager reports: 'wpa_supplicant authentication may have failed', and wpa_cli says: '4-Way Handshake failed - pre-shared key may be incorrect' (which obviously isn't).
Obviously, I looked for similar experiences, but found none (so, I may be doing something odd)
The router is a black box, no access to any logs, which is terribly unfortunate.
I'd need some guidelines as to how I may be able to debug this, unless someone already knows the way out and is willing to share. I'll do my best to provide any additional information that may be required, to sort it out.
Any pointers?
Cheers,
