Tråd: Option Icon 225 HSDPA usb modem.
iCON 225®
* Compact USB stick form-factor measuring 63x26x13 mm
* Multimode HSDPA/UMTS/EDGE/GPRS/GSM
* Worldwide coverage with quad-band EDGE/GPRS/GSM
* HSDPA connectivity at up to 7.2 Mbps
* EDGE/GPRS/GSM connectivity at up to 247 kbps
* Zero-CD Plug "˜n"™ Play technology
* Transparent support for IPSec and VPN technology
* Comprehensively tested on infrastructure and networks wordwide
* Future proof through upgradeable firmware in Flash Memory
About iCON 225®
The iCON 225 is a new generation of HSDPA product specifically designed for smallest size and highest performance at lowest cost. The iCON 225 is packaged as a very compact and light-weight USB stick, ensuring maximum portability and user convenience in fixed or mobile environments.
hand
The iCON 225 benefits from Option"™s extensive experience designing and producing the most advanced wireless devices applied to an HSDPA specific product. In particular, ease-of-use, radio and antenna performances are all leveraging Option"™s advances in their top-of-the-line HSPA products.
The iCON 225 is Option"™s response to the pressing market demand for a very small size yet high-performance wireless connectivity solution focused on consumer and prosumer segments.
The iCON 225 is usable worldwide thanks to quad-band GPRS/EDGE support. It can therefore also be used as a convenient data roaming solution for travelers, enabling access to e-mail and the internet virtually everywhere in the world.
MAC
Features
* Small USB stick form factor 63 x 26 x 13 mm, weight of only 40 g
* Multimode HSDPA / UMTS / EDGE / GPRS / GSM
* Worldwide coverage with quad-band EDGE / GPRS / GSM
* HSDPA up to 7.2 Mbps
* EDGE / GPRS / GSM data (up to 247 kbps) connectivity
* Zero-CD Plug "˜n"™ Play technology supported by 64 MB internal "˜nand"™ memory
* Comprehensively tested on infrastructures and networks worldwide
* Future proof through upgradeable FW in Flash Memory
* USB stick with USB connector protection cap"¢ Status LED indicators
* SIM card interface compliant with 3GPP 31.101 and 31.102 supporting 1.8 and 3V UICCs
* Environmental Operating temperature: 0 to +55ºC
* RoHS Compliant
PDF med lite specc's
http://www.option.com/docs/datasheets/O … asheet.pdf
