om du vill ha en router som kan stå som en vpn client som kopplar upp dig mot en ( pptp eller openvpn ) då rekomenderar jag du kollar på www.dd-wrt.com det är en firmware man kan flasha om flera routers med så routern blir grymt bättre.
här är en lista med routers den stöder http://dd-wrt.com/wiki/index.php/Supported_Devices
jag har själv bestämt mig för att skafa en router som har dd-wrt i från början
http://www.buffalo-technology.com/produ … er-router/
lite info om dd-wrt på routerns tilverkarens hemsida
What is DD-WRT?
DD-WRT, long a mainstay in the open source community, delivers an easy-to-use, versatile and extensive feature-set to a broader wireless networking audience. From the novice user to demanding professionals, this partnership provides best-in-class products for a wide range of consumers.
Serving millions of users worldwide, DD-WRT is the leading Linux based alternative open source firmware for wireless routers, enabling basic entry level equipment to act like an enterprise product. With an easy setup wizard, DD-WRT supports Buffalo's range of high power routers with professional features such as VPN (PPTP, OpenVPN), VLAN (tagging), Virtual AP (multi-SSIDs for multi-connection and security), RADIUS server, hot spot support, volume quotas, iPv6 support, detailed monitoring and a host of other high-end features which deliver a fully guaranteed, out of the box solution.
Buffalo brings a specially created, versatile, easy to use, and yet powerfully rich range of features to a wide audience - from novices to more experienced users demanding the professional applications contained within the AirStationâ„¢ High Power Routers which ship pre-installed with the DD-WRT firmware - delivering a fully guaranteed, out of the box solution.
// Ursekta Min Stavning Jag Är Dyslectiker //
// Sorry About My Spelling Im Dyslectic //
