Tråd: Taoglas (Apex & Apex II)
Taoglas.com
Interview with Taoglas https://www.youtube.com/watch?v=IjUb4JNVbYg
____________________________________________________________________________________
Apex II (TG.35.8113)
698~960 MHz 6.47 dBi Peak Gain
1920~2170 MHz 6.44 dBi Peak Gain
2500~2700 MHz 8.14 dBi Peak Gain
Apex II - Ultra-Wideband 4G LTE Antenna
LTE/HSPA/GSM/CDMA/DCS/PCS/WCDMA/UMTS/GPRS/EDGE/GPS/Wi-Fi
698~960 / 1575.42 / 1710~2700 / 5150~5850MHz
Typical 50%+ Efficiency and 3dBi+ Peak Gain
SMA Connector with Hinged 90°
L= 224mm
R/AL=196.9mm
W= 49mm
Datasheet
http://www.taoglas.com/images/product_i … 5.8113.pdf
Apex (TG.30.8113)
700~800 MHz 3.5 dBi Peak Gain
824~960 MHz 1.8 dBi Peak Gain
1710 ~ 2170 MHz 6.4 dBi Peak Gain
2400~2800 MHz 5.1 dBi Peak Gain
Apex - Ultra-Wideband 4G LTE Antenna
LTE/GSM/CDMA/DCS/PCS/WCDMA/UMTS/HSDPA/GPRS/EDGE/GPS/Wi-Fi
698~960 / 1575.42 / 1710~2700MHz
Typical 70%+ Efficiency and 3dBi+ Peak Gain
L= 185.9mm
R/AL=162.5mm
W= 49mm
Datasheet
http://www.taoglas.com/images/product_i … 0.8113.pdf
Apex (TG.30.8113) $14.17
http://www.digikey.com/product-detail/e … ND/3724547
Apex (TG.30.8113) $29.99
http://3gstore.com/product/4069_3db-cel … a-sma.html
2st Apex (TG.30.8113) $45.00
http://3gstore.com/product/4187_pair_3d … a-sma.html
