Tråd: Huawei E3236 med Ubuntu?
Hej forumet,
Har precis fått hem en Huawei E3236 från Telenor. Jag har googlat men inte hittat någon guide som visar hur man kan konfigurera Ubuntu för att fungera med dongeln. Har någon av er erfarenhet av detta?
Sv: Huawei E3236 med Ubuntu?
Hej, jag såg denna guide som bör vara liknande. Detta är för hilink modell men bör funka likadant i princip på vanligt.
This is how I got it to work on Arch Linux:
First I inserted the Telenor SIM in my mobile phone and removed the PIN code.
Then I followed [these instructions](http://ubuntuforums.org/archive/index.p … 08275.html) to get mbbservice running. Go to https://docs.google.com/open?id=0B4oQlH … lNXbFRWYjQ and click Download. Unzip, and inside the linux_mbb_install directory
    chmod +x install
    ./install
Now you have a file called /usr/local/MobileBrServ/mbbservice. You can either execute that file manually, or put it in some upstart/systemd/whatever script.
Then I put the SIM back in the modem and plugged it into my computer. The E3236 didn't show up in /dev/ttyUSB* for me, presumably because it's a ["HiLink driverless" modem](http://www.huaweidevice.co.in/Products/ … i-Link.php). When I connected the E3236 modem, `lsbusb` gave me
    Bus 004 Device 007: ID 12d1:14db Huawei Technologies Co., Ltd.
When I typed
    dmesg -T | grep -i usb
I got
    [Fri Dec 27 17:14:40 2013] usb 4-1.2: new high-speed USB device number 7 using ehci-pci
    [Fri Dec 27 17:14:40 2013] cdc_ether 4-1.2:1.0 eth1: register 'cdc_ether' at usb-0000:00:1d.0-1.2, CDC Ethernet Device, 58:2c:80:13:92:63
Then I created `/etc/network.d/eth1` with the contents
    CONNECTION='ethernet'
    INTERFACE='eth1'
    IP='dhcp'
Now, typing `netcfg -u eth1` brought up the interface. When I open a browser and go to http://192.168.1.1 I get the Telenor status page.
