Tråd: Bugg i FW på Mr3420 Routers i DDns
Har upptäckt och kontaktat Min kontakt på TP-Links support om att det finns en bugg i FW då gällande Dynamik DNS clienter. Det visar sig att router i dagsläget endast stöder 3G modem med denna function....men att dom nu uppmärksammat problemet och skall fixa till det.
"Citat"
Dear Jonny,
Here is the update for this problem, I have got the latest feedback from R&D colleague and there is one firmware bug existed that the DDNS module cannot support 4G modem.
Regarding to this case, we will start to cooperate with colleague in other Department to fix, unfortunatly I cannot provide the accurate schdle for this part. Thank you for your valuable feedback and any update I will keep you informed.
Best Regards!
"Slutcitat"
Asus main Router AC68U, 2st poynting riktantenner,5st Rt N12D1 Routers som Ap & Repeaters, Buffalo NaS, 12st ip cams (thinking, do I got the IP-Cam addict desice? )
