Sv: Open WRT för TP link ger LTE modem full hastighet
Säger det samma
Ok
![smile](http://www.mobilabredband.se/forum/img/smilies/smile.png)
MobilaBredband.se © Störst på Mobilt Bredband sedan 2007 » TP-LINK » Open WRT för TP link ger LTE modem full hastighet
Sidor Föregående 1 … 9 10 11 12 13 Nästa
Säger det samma
Ok
Förklarade saken i detta inlägg:
http://www.mobilabredband.se/forum/post … tml#p54262
Men posterna går om varandra som sagt...
Ok igen och något helt annat
https://play.spotify.com/album/5My0HgbxNKtsz4qg9MwkHq
Vilken tjej!
Ny version ihopknådad av dairyman.
This is sort of anti-climatic after Sam's neat hardware mod but here goes.
There is a new Huntsman release dated 2013-11-10 now available in both Red and Yellow versions.
Like all recent releases there are no big new features but mostly fixes for outstanding problems.
New here :
The SMS Messaging script has been rewritten so it should handle more types of messages without problems. It doesn't yet handle 16 bit Unicode so Chinese messages still don't work.
Custom DNS now works for QMI modems.
More tethered phones are supported and more ethernet modems will work out of box.
The MR3420v2 now has USB Power Toggling in the Red version and working Scheduled Modem Shutdown in both versions.
The old OpenWRT web interface theme is again available.
More routers are now supported. New routers include :
TP-Link MR10U, MR13U, WR710N and WR2543N/ND
Mercury MW4530Rv1 (a WNR4310 clone)
Dlink Dir505, Dir825 and Dir835Plus more modeswitch data has been added from the Usb-modeswitch forum to support more modems.
We now support 32 routers and over 50 modems.
Get it, beat it and report the problems. Another round of development is starting.
Testing
EDIT Sen är vi då på sidan 92/part 5 i denna megatråd.
http://forums.whirlpool.net.au/forum-re … 8&p=92
Vi har en ny ROOter igen
In a very feeble cry for help, I've uploaded a new Huntsman release dated 2013-11-23.
Both Yellow and Red versions are available.
Features :
A new Connection Monitor page that adds continuous ping and traceroute to the Keep Alive (renamed Monitor with Restart). Blow all your bandwidth pinging some poor website, see if I care.
Fix for the MF823 so it should connect correctly now.
Added firmware for the WR842N/ND V2, just added to OpenWRT in the last couple of days.
Added a Tutorial page on linking routers together using the Wifi.
The Red version for all 8Meg routers now contains the following storage packages :
kmod-usb-storage
kmod-usb-storage-extras
kmod-fs-ext4
kmod-fs-vfat
ntfs-3g
fdisk
block-mountThese should allow setting up a USB drive on the router. Samba and other packages should be downloadable without kernel dependency problems.
As a side note, a new release now requires 350Mb of firmware to be uploaded.
Now it's off to redo the Bandwidth Monitor feature and fix getsig once and for all.
Testing!
Jag testar E3276 med org telia fw tillsammans med MR3420 v 2.2 i senaste röd Huntsman version och kommer inte upp i mer än DL 31, UL 13,5 fast jag får DL 48, UL 18 med modemet direkt till PC. Samma resultat med E392. Nätet är LTE 1800 där man som mest kommer upp i DL 60.
Vilka farter får ni med E3276 i Huntsman?
Tethering med usbansluten ZTE mifi
Testade igen med MF93D usb-ansluten till MR3420 v2.2 rootad till senaste röd av den 23 novembe i förhoppning att de ska ha utökat tetheringfunktionen. Med bara MF93D får jag DL 38 och UL 5,4 på LTE 1800,vid SINR 20. Man får en gnutta internetåkomt via Huntsman innan det låser sig. I signal/cell info sägs no modem present men mifin finns i device debuginformation. Lägger till den infon senare.
Det känns som om det skulle kunna funka och det funkar ju med tp-link org fw.
Alla WRT är i konstant BETA.
MF93D kan jag inte finna bland de modem som stöds.... är du angelägen så be dairyman kolla på saken
http://ofmodemsandmen.com/supported.html
Tack, ska göra det.
Ny version
Huntsman 2013-12-20 Yellow (R36486), Red (R39076) – Christmas release
Same Red OpenWRT version as 2013-12-18, as newer releases appear to be buggy
Fixes a programming bug in Bandwidth monitoring
Huntsman 2013-12-18 Yellow (R36486), Red (R39076) – Christmas release
The Red version uses the very latest OpenWRT revision (R39076) so it hopefully has fixes for those annoying little problems in the last release, however feature wise things are a bit thin.
Bandwidth Monitoring is revamped and appears to work properly now. There are a few changes in the Bandwidth Monitor web page as well. Data for individual IP addresses is gone and has been replaced by data amounts for the different modem network interfaces.
If you use different modems in the router it will show the amount of data that has passed through each modem, assuming that they used a different interface, like wwan0 or 3g-wan. Also shown is the "base" amount, which is the data that was backed up before the last router reboot.
Support for the WR1043v2 has been added.
http://www.ofmodemsandmen.com/
Ny ROOter, bugfix utgåva
In a burst of energy that didn't last I've uploaded a new ROOter version dated 2013-01-25.
This is a bug fix release with a few more routers supported.
The multiple getsig problem is fixed for good.
The Bandwidth Monitoring has more changes to get rid of the occasional bogus values appearing. Or I hope they do.
Something that won't be noticed, but makes a difference, is that the ROOter start up has been integrated into the regular OpenWRT boot up sequence. No more more using rc.local to start the ROOter scripts.
New routers supported are :
TP-Link WR720V3
MyNet N600 and N750
Hame MPR-A2Not too exciting but a step towards bigger and better things.
The next release will be a big one, at least for 8meg routers. It will have dual modems, mbim support and proper USB storage support. All nearing completion now.
And the energy has faded away. -o.o-
http://forums.whirlpool.net.au/forum-re … ?t=2207038
Efter krånglet med Tre förra veckan började jag kolla in MR3420 med OpenWRT (Huntsman av den 25 januari 2014) och E353 HiLink. Det fungerar bra men man måste ändra i route-tabellen så den pekar på HiLink-modemets IP-adress. Det är litet kryptiskt sagt i ofmodemsandmen.com:
http://www.ofmodemsandmen.com/hostless.html
Alltså:
1. BYT IP-adress i E353 HiLink (eller annat HiLink-modem) eftersom 192.168.1.1 kolliderar med OpenWRT. Till exempel till 192.168.1.99.
2. Gå in i OpenWRT Network/Static Route och ändra wan till 192.168.1.99.
Nu hittar OpenWRT HiLink-modemet och allt fungerar utom Network Status och SMS - som meddelas i dokumentationen i ofmodemsandmen:
"Because these modems appear as an Ethernet device when plugged into the router there will be no information displayed on the Network Status page. The same thing applies to SMS Messaging, as the modem is not accessable using AT Commands like a regular USB modem."
HiLink måste vara i Auto Connect mode.
Varför inte byta i routern istället, till tex 192.168.1.2
Visst, men man måste ändå sätta wan i Static Route till modemets adress. DHCP sätter in routerns adress som gateway och det fungerar inte utan datorn måste gå direkt till modemets adress.
Man kan också ändra i datorns route-tabell men då fungerar inte routern för andra datorer (utan att man ändrar i alla datorers route-tabell).
Verkar struligt :-)
Hilink, nej tack
Nåja, att ändra en parameter är inte så farligt. Jag gillar HiLink därför att den har inbyggd router och E353 fungerar verkligen utmärkt direkt i datorn. Kopplar upp mycket snabbt. Den använder jag mest då jag är på resande fot. I huset där jag har telefoner, kamera och annat så har jag en E392 kopplad till MR3420 för att få flera uttag. Men E392 kopplar upp långsammare så den är inte så lämplig för resor.
Dairyman postade månadens statistik, kul för honom som lagt ner massvis med gratis arbete!
Almost forgot the stats for February.
6250 firmware downloads, 12600 unique visitors. Slightly down from last months record numbers and almost identical to Decembers numbers.
Still, a very good month.
Russia was far out ahead in the country list with over 7gb of bandwidth. Indonesia was second with 2gb. No one else had more than 1.5 gb.
Russia is ROOter country. Olympics maybe?
Overall bandwidth was the same as last month at about 38gb.
Traffic is still coming from a large number of forums and now some is coming from the OpenWRT wiki (thank you WF).
Google results are climbing as well with about 2700 visitors from it.
Not too bad for a month with no new releases.
Dairyman har en ny test-version ute, Funnelweb
FunnelWeb is the developmental version of the ROOter firmware. It has all the features of Huntsman and new ones of its own. These features may need testing by the user in order to perfect them.
The smaller routers with only 4 meg of Flash RAM do not gain any new features with this version because of lack of memory but do have support for several new modems and some bug fixes. If you are not experiencing any problems with your Huntsman ROOter then there is no need to update to FunnelWeb.
Features of FunnelWeb for 8 meg and larger Routers
Automatic mounting and sharing (using Samba) of USB storage devices.
OpenVPN with a web interface for configuration.
Media Server fully compliant with DLNA/UPnP-AV clients.
WAN Manager to allow setting up a DSL/modem failover system and load balancing.
http://ofmodemsandmen.com/downloads.html
Om funktionerna:
http://ofmodemsandmen.com/fwtut.html
Själv har jag just nu bara mitt ML-13U hemma och det har bara 4MB flashminne.
Kanske dags att skaffa en WR710N
Finns de med 64mb
Finns de med 64mb
Vika då som är i resestorlek?
Jag får inte alls lika bra fart som när jag stoppar in E3276 i datorn direkt. Kör med MR3420 ver2 och röd Huntsman från 25 januari -14. DL i MR3420 ger säg 30 men i datorn 60. UL är också snabbare men har inte skrivit upp de siffrorna. Jag har snabbt växlat mellan dator och MR3430 flera gånger (3) och samma sak upprepar sig. Har inte testat allra senaste versionen från 13 april.
Jag har också två MR3420 ver 2 där den ena routern orkar driva modemet men inte den andra. Extra stark nätadapter på 3A hjälpte inte, dock blinkar modemlampan alltid, även med originaladaptern, så lite ström får den allt. Om jag sätter in en USB-hub går det dock bra men det ser stökigt ut i köksfönstret.
jonasolof skrev:Jag testar E3276 med org telia fw tillsammans med MR3420 v 2.2 i senaste röd Huntsman version och kommer inte upp i mer än DL 31, UL 13,5 fast jag får DL 48, UL 18 med modemet direkt till PC. Samma resultat med E392. Nätet är LTE 1800 där man som mest kommer upp i DL 60.
Det är ett känt problem som nyligen uppmärksammats med drivrutinen cdc_ncm och E3276 och kommer ta lång tid innan fixen hamnar i Openwrt/Rooter. http://whrl.pl/RdXLvL
För övrigt så fungerar E3276 på MR3420 v2 med ny firmware (3.4 2014). Kan laddas ned från tp-link.com. Det som inte fungerar i den versionen är signalstyrkan som hela tiden visar noll fastän signalen är mycket god och hastigheten också (men prepaid-kortet begränsar farten så jag kommer bara upp till 12 Mbit/s på grund av det).
