Tråd: LAN -> WLAN access
Hi there,
I have a wireless IP camera and for some reason it is not accessible from my desktop computer that is connected to the 4GR's LAN port:
Starting Nmap 5.21 ( http://nmap.org ) at 2012-09-08 19:49 EEST
Nmap scan report for 192.168.1.124
Host is up (0.0044s latency).
Not shown: 999 closed ports
PORT   STATE    SERVICE
80/tcp filtered http
Nmap done: 1 IP address (1 host up) scanned in 11.92 seconds
If I use a computer that is connected to the 4GR via WLAN, the http port is shown as open and the IP camera is accessible so the 4GR must be somehow restricting access to the hosts connected to the WLAN... Is there any way to change this, couldn't find anything related to this from the modems control interface...? Also if I connect the IP camera to the router with a cable, the camera is accessible from the desktop computer...
The Cosmic Balance must prevail
Sv: LAN -> WLAN access
Ok, did some further investigating and it seems that the router filters port 80 for any host attached to the WLAN from the LAN side. Is there any reason for this? Just upgraded to the latest firmware (6.1.1) but it had no effect on this. SSH and other services in other ports work fine but of course filtering the standard http port is an issue...
3 Senaste redigerad av jonasolof (2012-09-13 07:56:46)
What if you change the port settings in the camera so as to avoid 80 or 8080?
router have a wlan webinterface that resides on port 80.
try changeing this in settings, then port 80 shild work.
