Finns ett fint redial script här på forumet men de funkar bara med huawei modem, eller modem som skapar en modem anslutning.
Options modem blir som en trådlös enhet.
Ang firmwaren så hörde jag tidigare att när man uppgraderade icon modemet så byttes drivisar osv så därför sluta det funka.
Så det blir mer eller mindre som ett helt nytt okännt modem, så draytek måste anpassa om det för den.
Frågan är om det inte går att nergradera.
Edit: Tror inte det går att nergradera.
MSM6280 Based FW Release Notes,
General 7.2 firmware release note
1.5 Firmware Versions and upgrade/downgrade remarks
Two different HSDPA 7.2 firmware builds exist for the MSM6280 products: one
for NOR flash memory based devices and one for NAND flash memory based
devices. Due to the several differences in flash technology, a different firmware
build/image is needed. It is not possible to handle these differences at run-time.
The following table shows an overview of which device is based on which
memory technology.
1.5.1 Important Upgrade Remarks
1. It"™s possible to upgrade a product from a firmware version 1.x.x to a firmware
version 2.x.x. But once a product has 2.x.x firmware it"™s not possible to
downgrade to a 1.x.x firmware version.
2. When upgrading from Fuji-Ex firmware 1.x.x to a 2.x.x firmware, it is
recommended to use 2.4.3 or higher as some additional changes in the file
system are implemented to be compatible with the file system of the 1.x.x
firmware.
3. Please be aware that the actual firmware build is the same for each of the
above products, but the engineering/commercial applications to upgrade the
products differ!
4. Important to know is than when a firmware build for Fuji-Ex or D-racer has the
same version number than any of the other products above, the same
Qualcomm stack, fixes, features, "¦ are implemented!
Next is an overview of recommended upgrade combinations.
