Tråd: LTE redan passe...? LTE- Advanced !
LTE- Advanced,
när kommer den månne tro, 1/10 av den 'upp till' vore helt ok
LTE- Advanced LTE-Advanced extends the technological principles behind LTE into a further step change in data rates. Incorporating higher order MIMO (4x4 and beyond) and allowing multiple carriers to be bonded together into a single stream, target peak data rates of 1Gbps have been set.
LTE-Advanced also intends to use a number of further innovations including the ability to use non-contiguous frequency ranges, with the intent that this will alleviate frequency range issues in an increasingly crowded spectrum, self back-hauling base station and full incorporation of Femto cells using Self-Organising Network techniques.LTE-Advanced will be 3GPP’s technology as a candidate for the ITU-R IMT-Advanced process, which is intended to identify ‘4G’ technologies.
http://www.gsmworld.com/technology/lte.htm
