Tråd: Glocalnets USB modem
Vissa kanske undrar vad det är för modem som Glocalnet använder sig av när de nu har lanserat mobilt bredband.
Usb modemet är av märket Option.
iCON 225®
* Compact USB stick form-factor measuring 63x26x13 mm
* Multimode HSDPA/UMTS/EDGE/GPRS/GSM
* Worldwide coverage with quad-band EDGE/GPRS/GSM
* HSDPA connectivity at up to 7.2 Mbps
* EDGE/GPRS/GSM connectivity at up to 247 kbps
* Zero-CD Plug "˜n"™ Play technology
* Transparent support for IPSec and VPN technology
* Comprehensively tested on infrastructure and networks wordwide
* Future proof through upgradeable firmware in Flash Memory
About iCON 225®
The iCON 225 is a new generation of HSDPA product specifically designed for smallest size and highest performance at lowest cost. The iCON 225 is packaged as a very compact and light-weight USB stick, ensuring maximum portability and user convenience in fixed or mobile environments.
hand
The iCON 225 benefits from Option"™s extensive experience designing and producing the most advanced wireless devices applied to an HSDPA specific product. In particular, ease-of-use, radio and antenna performances are all leveraging Option"™s advances in their top-of-the-line HSPA products.
The iCON 225 is Option"™s response to the pressing market demand for a very small size yet high-performance wireless connectivity solution focused on consumer and prosumer segments.
The iCON 225 is usable worldwide thanks to quad-band GPRS/EDGE support. It can therefore also be used as a convenient data roaming solution for travelers, enabling access to e-mail and the internet virtually everywhere in the world.
MAC
Features
* Small USB stick form factor 63 x 26 x 13 mm, weight of only 40 g
* Multimode HSDPA / UMTS / EDGE / GPRS / GSM
* Worldwide coverage with quad-band EDGE / GPRS / GSM
* HSDPA up to 7.2 Mbps
* EDGE / GPRS / GSM data (up to 247 kbps) connectivity
* Zero-CD Plug "˜n"™ Play technology supported by 64 MB internal "˜nand"™ memory
* Comprehensively tested on infrastructures and networks worldwide
* Future proof through upgradeable FW in Flash Memory
* USB stick with USB connector protection cap"¢ Status LED indicators
* SIM card interface compliant with 3GPP 31.101 and 31.102 supporting 1.8 and 3V UICCs
* Environmental Operating temperature: 0 to +55ºC
* RoHS Compliant
PDF med lite specc's
http://www.option.com/docs/datasheets/O … asheet.pdf
