Tråd: DreamBox with DOvado 3GN
Can anyone tell me the configuration of DreamBox with DOvado 3GN
i have dovado 3Gn n Dram Box 500
MobilaBredband.se © Störst på Mobilt Bredband sedan 2007 » Dovado » DreamBox with DOvado 3GN
Just put the RJ45 cable in the DB from the Dovado router.
Be sure that the Dovado is configured and has internet connection before.
my dovado is working fine as i am connected to wan port of my dovado router ....will do it first and if i get something wron then will post it here
The WAN port of the Dovado is only to use if you have another internet connection, like DSL/Cable/LAN, then you should connect that to WAN.
The DB should be connected to one of the LAN ports.
Thanks
